Bernard (guest)
Guest
Posts: n/a
porsche 996 2000 . ac working but not cold enough. 15 degree difference with outside and not good in Florida. I cleaned the evaporator which was molded , changed blower, changed both fans they are working very hard in Florida checked pressures low 45 high 200 @ ac on low and @ 2000 RPM . I clamped the how water to the heater no difference and I can hear the flaps inside working some time ago the vents have been blowing pieces of foam though.
what else can I do? Flush? renew dryer and expansion valve? or new evaporator? If I renew, vacuum....where do I put the oil in and flushing with what and from which line? reverse or along the flow of the system?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-28-2015, 06:17 AM
Nick at Pelican Parts's Avatar
With a low side of 45 I would expect to see the high side about 25 pounds higher. I would check if the charge is low.
- Nick
Cajundaddy's Avatar
Also foam out the vents means your mix flaps are falling apart. There was a DIY mix flap repair from the frunk side on Renntech a while ago that proved effective and far easier than removing the dash to get in there. This is a common problem in high humidity areas.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 08-28-2015, 06:43 AM
