Banned
Send a message via ICQ to philipjadler Send a message via AIM to philipjadler Send a message via Yahoo to philipjadler Send a message via Skype™ to philipjadler
Question Coolant leak causing cylinder #6 misfire?
I've had a flashing temp light on my 1999 Boxster the last two weeks, finding that the coolant reservoir is also draining real fast. Driving this weekend my CEL came on so I attached my OBD2 tester and came up with code P0306, "too many misfires within the allocated time" on cylinder #6.
So my question is could the misfire be caused by coolant dripping on the coil on 6, causing it to misfire? I'm trying to find a relationship between the two, and the proximity of the coolant reservoir to #6. It can't be a large leak, because my trunk carpeting is dry, and I haven't noticed any pooling under the rear passenger wheel
well.
Thoughts? Thanks.
Old 03-02-2016, 06:51 AM
JFP in PA's Avatar
I would be doing a leak down test on #6, you may have a more serious issue.
Accrochez-vous bien de vos rêves..........."
Old 03-02-2016, 09:03 AM
remove & inspect #6 sparkplug
Old 03-05-2016, 10:02 AM
It's happened before:
FS: '98 Boxster Engine (#6 cylinder bad).
Old 03-05-2016, 10:05 AM
jesiv's Avatar
Does the exhaust have any color? White blue or black?
"While driving my Boxster on twisty roads for hours is absolutely no replacement for spending quality time with my wife and family, it is at least why I keep my Boxster."
2003 Boxster S Guards Red - Daily Driver
1975 914 1.8L Malaga Red - Was Driver
Old 03-06-2016, 06:02 PM
