ScoobyDoo555 (guest)
Guest
Posts: n/a
I've got the ABS/PSM lights coming on my MY99 996 C4 when I press the brake pedal. The lights also come on when coasting. I'm suspecting the switch as I now have no brake lights either even after switching the car off to reset the ABS/PSM.... new brake light switch? :
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Brake Pedal Switch Replacement / Clutch Pedal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 11-04-2015, 06:21 AM
Nick at Pelican Parts's Avatar
Could be. Checking for fault codes would be best, for the warning lights. However, with the lack of brake lights, I think you may be on the right track. Fix the lights, then see if the problem persists.
- Nick
