Joshieboy (guest)
Guest
Posts: n/a
I have a 2011 948 cayenne s. Engine light came on my tech tells me he gets a code for the mass air sensor. Showed me where it was in the rear of the manifold. Part number 948 606 180 00 is that the correct part? I looked it up and says it is an air pressure sensor. If not the mass air sensor where is that located and the correct part number.
Thank you
Josh
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Mass Air Flow Sensor (MAF) Replacement and Troubleshooting - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 12-14-2015, 05:56 AM
Nick at Pelican Parts's Avatar
I’m not the best with part numbers.
Give our parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
