SpawnyWhippet's Avatar
I have a set of aftermarket 20" Porsche 918 style rims that came installed on a recent used purchase of a 05 Cayenne Turbo. They don't suit the Cayenne and I want to put stock rims back on. Would it be possible to fit these 918 rims to my 07 Cayman S? It currently has some fairly beaten stock 19" rims with 235/35 ZR19 tires on the front and 265/35 ZR19 on the rear.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Tire and Boxster Wheel Sizing - 986 / 987 (1997-08) - Pelican Parts Technical Article
1972 Porsche 911 coupe
2016 McLaren 570S
2016 Cayman GTS
2016 Land Rover LR4 HSE
2013 Mini Cooper S
Old 03-02-2016, 07:53 AM
Nick at Pelican Parts's Avatar
I am not 100% sure. Check with the owner's manual. It will have the max tire size you can put. If that size is noted, it should work. One thing to note, if you plan of using the rims, confirm the height, offset and width is the same as your current wheels.
- Nick
