XBob (guest)
Guest
Posts: n/a
Is it possible to install an 00-04 model roof with glass window including frame on a 98 model boxster?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Convertible Top Repair - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 04-15-2016, 11:09 AM
Nick at Pelican Parts's Avatar
I am not 100% sure. I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
Thank you Nick.
I did a little research and only a few parts are upgraded.
The back lid is the same (986 514 011 01) so i think the shape of the back of the roof is also the same.
But he transmissions are upgraded:
986 561 179 02 for -99 (left)
986 561 179 03 for 00- (left)
986 561 180 02 for -99 (right)
986 561 180 03 for 00- (right)
The transmissions are hold in place using 3 spacer bolt (per side)
986 561 789 00 -99
986 561 789 01 00-
but the transmissions also works on a pre 99 model with the correct spacer bolts.
so my conclusion so far is that it should fit.
Has anyone tried this before?
Bob
Old 04-15-2016, 01:30 PM
