Guest
Posts: n/a
I have a 1999 Boxster that will not start. Every thing electrical seems to work fine except the starter turning. This problem has happened twice before and corrected by disconnecting the battery and waiting twenty min. before reconnecting. This does not work now. What do you think needs to be replaced?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Ignition Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
Probably the starter. Check the signals to the starter to be sure.
- Nick |
one of gods prototypes
if it's a manual trans it could very likely be the clutch switch, do a search on how to bypass it......it's very simple if that's the cause
Brought to you by Carl's Jr. |
