P38J (guest)
Guest
Posts: n/a
Wayne,
I realize you did this conversion with a 2000 excellent job... I did not see in your posts what the original transmission was. I have a 1999 with a 5speed and even after reading all the posts, can't figure out if I need to change it out to make this conversion work or not. Do you know or is there another article to point me in the right direction ? Thanks for all the info so far ! Regards, Jerry
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Engine Conversion Project - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 10-01-2016, 04:55 PM
Nick at Pelican Parts's Avatar
2000 should be similar to the 1999 conversion. Maybe the easiest one to do. You should be able to use what is mentioned in the article.
- Nick
The 1999 5 speed will not be a problem with an engine of similar vintage from a 911. Going with even a year later engine, you get into issues with the electronic throttle system which came in in 2000..
Old 10-02-2016, 12:49 PM
