Replaced Immobilizer.....No Start Issue
I had a wet damaged immobilizer on my 2002 Boxster with Triptonic. Sent the ECU, Immobilizer and Key to Specialized ECU Repair. Kudos for the prompt service. Having replaced my parts, I still have a no start condition. Started doesn't engage, windows don't work and central lock from the dash doesn't function. Everything else seems to work. Top, HVAC, mirrors, signals, audio, power seat, seat heat horn etc. Checked the C-3 fuse and its fine.
Suggestions? |
Administrator
Hi Fred - I thought the below link to one of our site's tech articles may help you troubleshoot the start issue. If you have any other questions, feel free to post a Comment just below the article and someone will get back to you with more detailed info. Best of luck and hope this helps!
![]() Starter System Troubleshooting -Dmitry |
Take it to a shop that can verify the coding for your vehicle, and if any errors they can perform some diagnostics.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
