-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   I think my Cayman reached its expiration date (http://forums.pelicanparts.com/boxster-cayman-forum/931760-i-think-my-cayman-reached-its-expiration-date.html)
Brando 10-09-2016 04:53 PM
Sorry for the shakeyness up front. This started a couple weeks ago driving home from work. Car's been holed up in my garage since, haven't started it. Terrible clacking, increases with RPMs, driver's side. I'm really hoping it's just a collapsed lifter. I'll have to pull the oil filter for an examination to really know. Then comes the decision of servicing it, replacing the engine, or replacing the car. http://forums.pelicanparts.com/suppo...leys/shake.gif
Anyone care to weigh in?
<iframe width="640" height="360" src="https://www.youtube.com/embed/PZEbCo1JblQ" frameborder="0" allowfullscreen></iframe>
bell 10-09-2016 05:13 PM
start with the simple stuff first.....
to me I've heard loose spark plugs sound like that....
vintagecarlover 10-10-2016 08:54 AM
Post what u find.
Luccia at Pelican Parts 10-11-2016 07:44 AM
Typically, spark plugs being loose/cracked cause a chirp sound, from my experience at least. Some info on that HERE. Definitely sounds like it could quite possibly be related to the engine. You can always have it towed to a local P car shop to confirm. Here are just some similar threads/videos that sound similar to the one you posted.
http://forums.pelicanparts.com/boxster-cayman-forum/794012-chasing-cayman-s-lifter-noise.html
https://www.youtube.com/watch?v=qLkoENrBmck
Brando 10-14-2016 02:34 PM
Thanks for the links Luccia. Unfortunately my noise gets louder and more pronounced as RPMs increase. This tells me something is really slapping around internally. I'm going to see about offloading the car and just walking away. I can't afford a tear-down, rebuild, or engine swap. To be quite honest I've never owned a Porsche that was so fickle. It's been fun but I don't "love" the car.
Additional update - looks like it is not a [catastrophic] IMSB failure. Pulled the oil filter Tuesday night and just found some small pieces of rubber. Here's a view of the filter:
<iframe width="640" height="360" src="https://www.youtube.com/embed/LQIj3tQv8CU" frameborder="0" allowfullscreen></iframe>
BYprodriver 10-16-2016 09:02 AM
Sorry for your troubles, recommend you call Vision Motorsports in Laguna to start.
BoxSinIt 10-18-2016 09:52 AM
I say it's gone
Emo993 10-18-2016 10:41 AM
Brando, that is the outside of the filter correct. Mark
Brando 10-18-2016 01:29 PM
Yes Mark, the outside. I checked the inside - same, no metal.
BoxSinIt -> It certainly feels that way. I wish I could give this thing a Viking Funeral about now.
Cajundaddy 10-18-2016 01:39 PM
Hmmmm, sounds like rod knock to me.
Yr and mileage? Any recent service done?
Dwain has a nice shiny 4.2L with your name on it if you choose to go there. GT4 performance at 1/4 the cost.
BoxSinIt 10-18-2016 05:04 PM
I heard the same sound and the car still runs.. Turned out the crankshaft and a rod was damaged ��
BoxSinIt 10-18-2016 05:06 PM
I'll add that my oil filter did have metal shavings..
Brando 10-20-2016 07:00 AM
Cajun -> Year is 2006 and mileage is 136k. Recent service would be: New rear tires, new MAF, oil change ~3k ago, new spark plugs and coils earlier this year, Softronic ECU tune in March. Nothing that would cause this. If I had the money for that 4.2L, I would jump on it for sure. Going through a house purchase and still owing on the car has made it impossible to overhaul this - otherwise I would be looking at a LS7 swap and AZ plates.
BoxSinIt -> Sorry to hear that. Seems these engines are not as bulletproof as we hoped. I am seriously longing the the days of my 1987 Carerra that had none of these problems, my biggest concerns were lifting in a turn and the stereo being too loud for my wife.
onewhippedpuppy 10-21-2016 01:06 AM
I would definitely take it to an experienced shop and exhaust my options before just dumping it. No chunks of metal is a promising sign, a few thousand dollar repair is definitely better than just dumping it with a "bad" engine.
Brando 10-21-2016 06:39 AM
I am thinking the same, Matt. First reply from the wife: "And how much is that going to cost?"
I guess if I got it repaired I could then sell as a complete running car - get more cash for it.
Jeff Alton 10-21-2016 04:49 PM
Burning any oil?
BoxSinIt 10-21-2016 05:27 PM
Well my problems started with a cracked head, which led to the an oil/coolant mix.. Then it went down from there. But I had a few overheating issues in the past (I admit I shouldn't of kept driving) that I think led to the cracked head.. Other than that the car was rock steady. 14 years of driving it very hard (2002 Boxster S)
I still have it and its driving like a champ (rebuilt engine) 😃
j911brick 10-21-2016 10:06 PM
I would pull the pan; check compression and leakdown. do the basics before sending it to a shop. Doesnt sound good but sound is not 100% reliable. I had a 996 in my shop only making a very slight noise. Thought IMS probably. All 6 rod bearings were non-existant.
basicporsche 10-22-2016 03:48 AM
Bring it tp a pro just to get a diagnosis it can't hurt
Brando 10-22-2016 07:29 AM
Working in the garage yesterday, I am in agreement about getting it inspected. I'll give Hergesheimer's a call Monday. Just impossible to get anything done with a bike and a car in there, no room... It's either gotta go get fixed, or gotta go.
Oil consumption, I was at about a quart over the last 1100 miles. Luckily it also had no more than a poof of smoke when would I start it up (per usual).
Jeff Alton 10-22-2016 04:59 PM
What side is the noise most prevalent?
Brando 10-24-2016 06:38 AM
Hey Jeff - the noise is on the Driver's side.
Jeff Alton 10-24-2016 07:06 AM
Pull the #6 plug and compare its color to one from the other bank.
Brando 10-24-2016 11:31 AM
I will if able... It would be nice if it were something simple like collapsed lifter (or two) but who knows.
Jeff Alton 10-24-2016 07:03 PM
It very well may be a lifter, and hopefully that is what it causing the noise. But checking the plug is fairly easy and can quickly rule out a worst case scenario.
Cheers
Brando 10-29-2016 01:16 PM
Update time... I am a little sad, but also relieved. The guys at PRO Motorsports in Burbank was interested in taking the CS off my hands. I will miss it, for sure, but I did not love this car like my 1987 Carrera. Maybe some day down the line I'll take another Porsche into my stable. For now I will enjoy my Victory Octane as a daily driver.
mikefocke 10-29-2016 01:21 PM
Drive safe.
aigel 11-04-2016 03:54 PM
So, what was the verdict if any?
fiily 11-04-2016 05:37 PM
Don't buy any cayman/boxster/911 from 98-2008 is my verdict.
I have been contemplating selling my 944 turbo and 944 n/a to pickup a cayman, but between the ims failure, cracked blocks, d chunks, I think my 951 and 944 are my best buddies in terms of reliability and performance compared to any 996/986.
944 parts are cheap and repairing them is frustrating at times, but they are very simplistic builds , mind the 25+ year old electronics and wiring.
I see so many people dumping their 911's, cayman's, boxsters with bad engine's. This obviously kills your resale for the 3 aforementioned vehicles from 1999-2008.
Knowing my engine could grenade at a moment's notice would make me dump the car asap, especially when replacement engine are insanely expensive($6-10k) and really a bad money decision to fix.
I blame porsche at the end of the day, they have screwed over owners, and any future owners of these beautiful cars. Shame on them.
JFP in PA 11-04-2016 05:46 PM
I'd really like to see you try to buy a 1998 Cayman, especially as they were not produced until 2006......
As for the early M96/97 engine cars losing their value, those without IMS retrofits will suffer, while those that have been retrofitted hold theirs, particularly those with the permanent IMS Solution installed.
Brando 11-04-2016 05:59 PM
No news from the shop that bought it. They said they wanted to rebuild the engine anyways (permanent fix to IMSB, address any "while we're in there" items). I'll check in with them in about a month, see what they've done.
fiily 11-04-2016 06:58 PM
Right, my mistake 98 boxsters. Either way, my condolences. Buy a 944 and keep you car out of the garages that love seeing m96/97 engine car's come in on flat bed's.:D
j911brick 11-04-2016 11:31 PM
Actually the retrofits dont mean sqwat. They fail as well. But for the most part IMS failures are rare these days. But other things are failing like valve springs and rod bearings.
Brando 11-05-2016 06:44 AM
I am starting to think the M96/M97 design has a few character flaws. D-chunking, valvetrain problems, IMSB... I don't think I would ever gamble on that again.
If I do come back to buy a Cayman or Boxster from that generation, it will get a LS6/LS7 swap, and I will budget accordingly. I am a fan of the 2006+ body style and the handling was superb. But I won't risk the catastrophically expensive engine failure (again).
onewhippedpuppy 11-17-2016 06:23 AM
By the time you invest $40k in properly swapping an LSX into a modern Porsche, you could have had a multitude of other cars.
I've posted it many times, you gotta pay to play. If you can't afford a potential issue that costs you thousands, you shouldn't own a Porsche. Every Porsche made has problems that can be super expensive. filly might be singing a different tune if he paid a shop to replace his clutch, rebuild his torque tube, and clean up the damage from a snapped timing belt. I love both my 911SC and 986S, but frankly the SC has the potential to cost me way more money.
cbonilla 11-17-2016 08:02 AM
As the owner of an '03 986S Tiptronic, I second this statement. Mine let go at 106k - so much for the conventional wisdom "if it's good at 30k it's good at 230k". Owned it since 2004/
Porsche left us with ticking time bombs and only stepped up to the plate if they failed in a specific window. I'm sure that the Class Action lawyers were paid handsomly. The rest of us, not so much
CB
JFP in PA 11-17-2016 08:19 AM
Actually they do mean quite a lot in terms of resale values; we do PPI's and have seen several cars that were commanding a premium because of the retrofit, and the buyer's happily paid it, particularly if the car had the IMS Solution retrofit.
As for retrofits failing, we have never seen one of ours fail in the eight years we have been doing them, and have not heard of another shop losing one either. I have read (online) about failed retrofits, but they were using either off the shelf or aftermarket steel replacement ball or roller bearings. Of the more than 25,000 LN ceramic hybrids installed, last time I spoke with Charles Navarro, few than 15 had failed, and most of them were traced to improper installation or the ingestion of metal debris from another engine component failure. If memory serves, only one failure remained unresolved at the time of the conversation.
As for fewer IMS failures still happening, I also would not count on that; we had one in the shop last week, and are expecting a flatbed with another car we suspect had a failure as well.
BoxSinIt 11-18-2016 04:54 PM
After the rebuild and DOF IMS retrofit, it's running strong. Looking forward to 14 more years! I think it's worth it.
Brando 11-19-2016 12:37 PM
Not sure if you meant it, but that came off quite a bit snobbish Matt. I'm no stranger to the cost of ownership with the Porsche brand. I've owned quite a few over the years (as have you). However the 986/996/987/997 platform by far was the most expensive in all regards and the least DIY-Friendly.
I had stated before that IF I went back to that generation of Porsches, it would be with an LS-7 swap and I would budget accordingly. Probably find a clean roller with a blown engine and go from there. Realistically, I'll probably get another 914 or 944. With a 914 there's plenty of conversion options and for 944s they're just plain fun to drive. I would have kept the Cayman S had I not been in the house-buying process.
Sadly this has been a learning process. I was able to buy the car, drive it for a number of years, enjoy it, and walk away when it went kaput. I consider myself lucky as there are many more stories where the same (or worse) happened and the owners ate the $20k+ to fix it. This generation is just not worth it IMHO.
onewhippedpuppy 11-24-2016 05:05 PM
Not intended to be snobbish, just reality. Any Porsche can cost you a LOT of money. Sorry you lost the lottery on this one, I've owned quite a few 98X and 99X cars and they've all been incredibly reliable and enjoyable.
