Hello Nick, I recently scanned the car and the computer showed code P0152, what does it mean? Also the car backfires but very rarely and shows irregular iddle at warmup and consumes a lot of fuel.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Oxygen Sensor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
That code is for a oxygen sensor stuck high. Likely faulty. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick |
Actually, the code indicates that the plus side of the O2 sensor wiring is grounded. I would disconnect the sensor and check to see if this is at the sensor or in the wiring harness itself.
| All times are GMT -8. The time now is 04:10 PM. |
