Cayman DR (guest)
Guest
Posts: n/a
Hello Nick, I recently scanned the car and the computer showed code P0152, what does it mean? Also the car backfires but very rarely and shows irregular iddle at warmup and consumes a lot of fuel.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Oxygen Sensor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 01-25-2017, 07:12 AM
Nick at Pelican Parts's Avatar
That code is for a oxygen sensor stuck high. Likely faulty. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
JFP in PA's Avatar
Actually, the code indicates that the plus side of the O2 sensor wiring is grounded. I would disconnect the sensor and check to see if this is at the sensor or in the wiring harness itself.
Accrochez-vous bien de vos rêves..........."
Old 01-25-2017, 09:08 AM
