-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Jacking Up (http://forums.pelicanparts.com/boxster-cayman-forum/943621-question-boxster-jacking-up.html)
JP (guest) 01-25-2017 07:34 AM
How about a photo of alternate lift points on 981's. We all know the factory holes. The problem is if the factory holes are used to raise the vehicle how to get a jack stand in place unless you use alternate chassis point. Talked to Porsche today and they discouraged me from using the Fabspeed's rear center "jack point" saying the mini-I-beam may be too light to support the entire rear end.
This post was auto-generated based upon a question asked on our tech article page here: Jacking Up and Lifting the Porsche Boxster on Jack Stands | 986 / 987 (1997-08) | Pelican Parts Technical Article
Nick at Pelican Parts 01-25-2017 07:34 AM
I am having someone look into this info, I will get back to, or someone else from pelican will. Thanks for the note and question.
- Nick
Dkennel 01-27-2017 09:37 AM
I use these quite,a bit http://www.jackpointjackstands.com/http://forums.pelicanparts.com/uploa...1485538472.jpg
You can lift high enough to get under the car safely to access oil drain and filter, I used them to change plugs on my 987. they will not go high enough to drop the engine lol
JFP in PA 01-27-2017 12:15 PM
Get a set of Lift Bars for the car; incredibly strong, you can jack the car to any height and still keep it stable:
http://www.renntech.org/forums/uploa...pspe5qc6rz.gif
Dkennel 01-27-2017 08:18 PM
Are those the Poken Liftbars, how vehicle specific are these? 986/987/981? What's cost?
JFP in PA 01-28-2017 09:21 AM
You need to Google Porsche Liftbars for their website, which has extensive model figment information. We have one set that works on 986, 987, 996 and 997 cars.
Dkennel 01-28-2017 11:19 AM
That looks pretty cool. Works great if you want to lift high on both axles.
JFP in PA 01-28-2017 12:22 PM
Incredibly well made and rock steady, even when the bottom of the car's tires are 24" off the ground on 6 ton jack stands. Super for working at the track.
