JP (guest)
Guest
Posts: n/a
How about a photo of alternate lift points on 981's. We all know the factory holes. The problem is if the factory holes are used to raise the vehicle how to get a jack stand in place unless you use alternate chassis point. Talked to Porsche today and they discouraged me from using the Fabspeed's rear center "jack point" saying the mini-I-beam may be too light to support the entire rear end.
This post was auto-generated based upon a question asked on our tech article page here: Jacking Up and Lifting the Porsche Boxster on Jack Stands | 986 / 987 (1997-08) | Pelican Parts Technical Article
Old 01-25-2017, 07:34 AM
Nick at Pelican Parts's Avatar
I am having someone look into this info, I will get back to, or someone else from pelican will. Thanks for the note and question.
- Nick
Dkennel's Avatar
I use these quite,a bit http://www.jackpointjackstands.com/
You can lift high enough to get under the car safely to access oil drain and filter, I used them to change plugs on my 987. they will not go high enough to drop the engine lol
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 01-27-2017, 09:37 AM
JFP in PA's Avatar
Get a set of Lift Bars for the car; incredibly strong, you can jack the car to any height and still keep it stable:
Accrochez-vous bien de vos rêves..........."
Old 01-27-2017, 12:15 PM
Dkennel's Avatar
Are those the Poken Liftbars, how vehicle specific are these? 986/987/981? What's cost?
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 01-27-2017, 08:18 PM
JFP in PA's Avatar
You need to Google Porsche Liftbars for their website, which has extensive model figment information. We have one set that works on 986, 987, 996 and 997 cars.
Old 01-28-2017, 09:21 AM
Dkennel's Avatar
That looks pretty cool. Works great if you want to lift high on both axles.
Dietmar
1987 911 Carrera
2008 RS 60 Spyder
Old 01-28-2017, 11:19 AM
JFP in PA's Avatar
Incredibly well made and rock steady, even when the bottom of the car's tires are 24" off the ground on 6 ton jack stands. Super for working at the track.
Old 01-28-2017, 12:22 PM
