just changed coolant fri and one of the steps was to pull fuse B1 for trans cooler. well in my 2004 boxster S B1 kills the inst panel. figured out B1 using pics of D3 from other job description on Pelican. Anyway apparently one of the only things wrong with this car is no fuse box map on the inside cover. Can anyone post one I can copy or suggest where to get this info? THX
Administrator
Welcome to the forum! I believe a diagram of the fuse box is in the workshop manual - you may be able to find an image online as well. Best of luck!
-Dmitry |
See if this helps
Link from a 2001
thank you sir
