Hello. Sorry for the bad english. I have problems with the engine running at idle. I cleaned the throttle and the MAF sensor. This partially helped, but then the problem manifested itself again.
When I disconnect the Maf sensor and start the car, it turns off. This is normal?
Today, after the problems started, I disconnected the Maf sensor. I tried to start a car. Then i reconnected the Maf sensor. The problem is gone. What does this mean?
Thank you very much for your help.
Boxster 986
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Mass Air Flow Sensor (MAF) Replacement and Troubleshooting - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 03-24-2017, 09:14 AM
Nick at Pelican Parts's Avatar
Disconnecting the maf sensor is not a test, so what happens when plugged or unplugged doesn't help to draw conclusions. You will want to monitor scan data for the maf at idle to see if it is reading incorrectly. if not, do not suspect it.
- Nick
