congalee (guest)
Guest
Posts: n/a
if a exhaust is rated 11 hp and flashing is rated 12 hp and header is rated 20 hp would the gain be the sum of 43 hp . How would you figure the actual gain?
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Cold Air Intake Installation - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 04-26-2017, 07:19 AM
Nick at Pelican Parts's Avatar
Good question. I usually assume any one mod can get 10, then all the mods can get 15 total. Only a dyno sheet will tell the truth.
- Nick
Every Boxster already has a cold air intake
As the intake air is taken from outside the car and not from inside the hot engine compartment.
And if you are expecting 40+ HP gain from the mods you cite, I have some swamp land you could buy.
Figure $100 per HP and beware of driveability problems with extreme approaches.
A list of mods I've seen is here.
Old 04-26-2017, 06:06 PM
