Lenny (guest)
Guest
Posts: n/a
Hi, I've a '98 2.5 and relais are different from your pic. How I can recognize it?
2nd question: in wich direction should I rotate to extract it? Thank you
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Fuel Pump Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 04-26-2017, 07:18 AM
Nick at Pelican Parts's Avatar
The relay should come out the same way. I would suggest you grab a repair manual, you should own one. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
