RE (guest)
Guest
Posts: n/a
I have a working slave connected to the hydraulic line, but I'm not able to install it back in place. When I push it into place, even with the assist of a quick clamp, it is 2-5mm shy of where it needs to be for the bolt to fit. Do you have ideas about what would cause this? Transmission was dropped and reinstalled.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Transmission Removal - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 05-24-2017, 07:03 AM
Nick at Pelican Parts's Avatar
Hydraulic pressure. You will have to compress the slave while you install it. Or release the fluid and bleed once installed.
- Nick
