Guest
Posts: n/a
The clutch on my 2003 BoxterS works perfectly but the clutch pedal had become very hard to push down...I believe there is a small "support" cylinder that helps depress the clutch pedal? Any advice, please
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Clutch Hydraulics Overhaul (Master Cylinder & Slave Cylinder Replacement) - 986 / 987 (1997-08) - Pelican Parts Technical Article |
No. You may have a failing pressure plate
- Nick |
