Guest
Posts: n/a
I checked power on both wires going to the strting disable clutch switch & have no power with key in on & starting position where do those wites tecieve power
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Brake Pedal Switch Replacement / Clutch Pedal Switch Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
I don't have wiring info for your vehicle. I would suggest you grab a repair manual, you should own one. It will have the wiring.
Give our parts specialists a call at 1-888-280-7799. - Nick |
Administrator
Manual here if needed: Porsche Boxster Service Manual (1997-2004), by Bentley Publishing - PelicanParts.com
