Torque spec: torx nut on trans mount?
Does anybody know this? I'm replacing the transmission mounts on a 2002 986 base with a tiptronic gearbox. I've checked the factory manual set, along with a number of books with little results. The two specs I came up with:
1) transmission support on transmission housing 24ft lb 2) hydraulic mount to carrier side section 48ft lb Thanks for any help or assistance. Regards |
Administrator
Hello - have you checked out the Bentley manuals for your 986? It should have all the torque specs and wiring diagrams for your car - link below.
Bentley Service Manual, Porsche Boxster 1997-2004, Hardcover - PelicanParts.com |
The Bentley manual has never been terribly helpful for stuff like that. The "101 Projects" book didn't have it either. Since the said torx is referred to as a "M12" hardware, the factory manual refers to other M12 hardware at 55 ft lbs. This is where I'll start, along with blue loctite.
It's too bad Porsche does not put out "Tech Spec Booklets" like the old days for their cars. Regards |
Accrochez-vous bien de vos rêves..........." |
Thanks for the comment though. ; ) Regards |
