-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   '01 Boxster windows don't retract when trying to open door (http://forums.pelicanparts.com/boxster-cayman-forum/969597-01-boxster-windows-dont-retract-when-trying-open-door.html)
AStevens 09-09-2017 04:00 PM
Hi folks - First post here. I have an '01 Boxster that I am only able to drive intermittently (months between turning it on). I usually keep it in the garage on a battery tender, and that's worked well for as long as I've owned it (4 years).
Today I went to turn it on, but neither window lowers when I lift the door handles. The battery seems to be charged, the dash lights up and the remote locks/unlocks the doors. When I put my ear near the door handle, I can hear a "click" as I lift the handle. It sounds like a solenoid or microswitch. I don't hear a motor attempting to turn.
There was an extended power outage in my area since I last turned on the car, so my best guess is the battery died during the outage and was recharged by the trickle charger after. I've seen several articles/posts on resetting the windows, etc., but how can I do that if I can't open the doors? I'm concerned that forcing a door open will damage the window.
Thanks in advance.
Dmitry at Pelican Parts 09-11-2017 12:43 PM
Hello and welcome to the forum! Take a look at the link below to a DIY tech article on our site that should help you get your door open. The second link should help address the window issue that you're having. Best of luck!
Porsche Boxster Door Lock Mechanism / Door Handle - 986 / 987 (1997-08) - Pelican Parts Technical Article
Porsche Boxster Window Regulator Replacement / Window Switch Replacement / Window Motor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
