Boxster engine weight
I have a 2.7 coming to put in my boxster project. Anybody got an idea how much it weighs? It's a 2002, include the alternator, air oil separator, and a starter, but no a/c compressor or throttle body.
I need to know if a light weight trans jack will work
Brian Lamberts
Tucson AZ
Old 10-26-2017, 05:45 PM
Stranger on the Internet
patkeefe's Avatar
Probably around 300# or so (a guess...I have no details). What is a lightweight transmission jack? I use a motorcycle jack on my 911 for the engine and the trans together. From my recollection of transmission jacks, one of those should work.
Patrick E. Keefe
78 SC
Old 10-26-2017, 08:16 PM
Thanks Pat. Yeah, I decided to use my motorcycle jack. If one is just swapping engines, do you need to remove the transmission (tiptronic) too?
Brian Lamberts
Tucson AZ
Old 10-27-2017, 07:32 AM
JFP in PA's Avatar
With a Tip, it is easier to drop it as an assembly and then split it; with a manual you can go either way.
And the engine alone weighs around 450 Lbs.
Accrochez-vous bien de vos rêves..........."
Old 10-27-2017, 07:49 AM
Thanks. I'll investigate that. Would give me the opportunity to replace the CV boots. Getting to sound like a bit of a long haul project.
Every new car/engine/trans project is quite a learning experience.
Brian Lamberts
Tucson AZ
Old 10-27-2017, 04:51 PM
