Send a message via Skype™ to Steph.Barretta
engine dies after warm-up cycle
will only restart after cool down, approx 5 minutes. Codes indicate bad oil temp/level sensor and bad pre-cat O2 sensors, also tiptronic has output speed sensor failure. water pump replaced so far to clear water temp issue. I thought I read somewhere that the oil temp sensor could cause this. anyone out there know of this?
Old 11-15-2017, 05:24 PM
more on engine dies after warm-up cycle
more info: ECM was tested with immobilizer and passed, tiptronic control module was swapped for another and did behave differently but not conclusively as engine died before any real testing could take place.
Old 11-16-2017, 10:55 AM
When you post
please give the model year of the car and the exact codes. It helps you get answers tailored to your specific problem.
Miles on the engine? Any mods? Last tune up?
Old 11-16-2017, 12:07 PM
1998 Boxster with Tiptronic. Codes are P0197, P0131, P0151, P0722. These reset after clearing and running engine from cold. There are other intermittent codes: P1602, P1115, and P1119.
Old 11-16-2017, 07:40 PM
JFP in PA's Avatar
P0197 - Oil temp sensor short to ground
P0131 - O2 sensor on bank 1 ahead of three way cat short to ground
P0151 - O2 sensor on bank 2 ahead of three way cat short to ground
Sounds like you have some electrical issues...............
Accrochez-vous bien de vos rêves..........."
Old 11-17-2017, 05:51 AM
