Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > Early BMW Cars (2002, Bavaria, etc.)
new 72 2002 owner
Hi, i don't have any pictures yet to post up, but will soon. The car looks pretty solid, has some rust, but can be easily taken care of. So the question since i'am new to the 2002, i'm sure people have lowered your cars, and how do you do it? lowering blocks? coilovers? i would like to bring the car down a few inches.. any suggestions are greatly appreciated for it or against it, thanks.
joe
Joe
2008 Toyota Prius
1978 Porsche 911 sc targa SOLD
Old 02-14-2006, 10:41 PM
Priced-out of Porsches.
mmastro's Avatar
Hi,
I'm also new to 2002 ownership, '74. I was looking at the parts I'll need for my build, and Ireland Engineering (google it) sells sport springs that lower the 2002 ~1.5 ". The only thing is that they recommend using Bilstein sport shocks and strut inserts w/ the springs as they are a little stiffer than stock.
Cheers,
Mike
SoCal
Old 02-17-2006, 08:03 AM
Senior Member
Leland Pate's Avatar
God, I love 2002's. I have one sitting at my mother's house.
Chief Architect and Mastermind,
SCWDP
Old 05-05-2006, 07:06 AM
Have a '72tii, put the Ireland anti sways and bilsteins, Kept the stock springs. Love the little bugger. Nice ride and flies through the corners.
Tempted to try the shorter springs. Also put a CR 5spd, 1:1 5th.
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
62 Twin Grille Roadster (getting close)
Old 09-21-2006, 09:25 PM
Tirebiter's Avatar
Re: new 72 2002 owner
joe
Back in the 80's, there were a couple of cost effective methods for lowering a 2002: The first was to remove the DOT required spacers that were installed in some US versions to raise the bumper height!! These aluminium spacers are located on the top of all four shock towers. Removal would lower the car about 3/4". The second was to cut the springs. Removing one coil per spring would lower the car about 1-1.5" as I recall. This method has the added advantage of stiffening the suspention as well....seems counterintuitive, but true.
Be carefull in thinking more is better.....once cut off your only recourse is to replace the spring if you find that you have gone too far. (too much in the rear is evident by wheels with excessive camber) Even with only one coil removed, you will find that you may have an issue with the rear tires rubbing the inner wheel well lip, especially if you run wider wheels/tires. If so, most people would carefully bend the lip to vertical by carefully tapping with at body hammer
I sure do feel a lot more like I do now than when I first got here......
2016 S1000XR,2001 R1100 SA: Wunderlich Seat, Staintunes, Wilbers F/R
2004 MV Agusta Brutale S
1973 BMW 2002 Touring tii, '12 LR4, 86 Mondial 3.2 QV, 02 996 Turbo
Old 09-22-2006, 09:04 AM
Joe, I read the reply regarding the spacers for the front struts. Get rid of those if it has them. Raise the car and remove the three 13mm nuts and the whole works will drop down enough to remove the spacers. That's a start. If it has the original springs just bite the bullet so to speak and get some new ones. Front and rear.
good luck,
rusty
virginia beach
Rusty
71 911E
55 PreA speedster
85 Turbo look Cab
Old 09-22-2006, 11:07 AM
