-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   R56 S starting issue... (http://forums.pelicanparts.com/mini-discussion-forum/1002894-r56-s-starting-issue.html)
scubus 07-21-2018 03:58 AM
I have a 2007 Mini S with just under 90K
It has worked flawlessly for the most part. Maintenance and minor issues only.
This morning I went out, hopped in, pushing in the fob, dash lights etc. came on, pushed the start button and everything went dead. Key fob licked in the dash can't be removed - not able to push it in etc.
I pulled the two relays with the engine picture on them and the lights came back on and there was an exclamation point in my tach. Pushed the start button and it fired right up. No, there is no rhyme or reason why I pulled the relays - desperation I imagine.
So I assumed it was one of the two relays.
Car ran fine all day, probably went through half a dozen start cycles, then at the grocery store the same thing happened. I figure I'll just pulled the relays again. You guessed it - it didn't solve the problem.
Five to 10 minutes later the lights came on and the car started without issue.
So, anyone have any idea what the problem might be?
Thanks!
[added:]
Is there a door interlock on the ignition? It happened again this evening, only when I turned OFF the car. The power went dead and the key would not come out. I slammed the driver door and everything came back on.
scubus 07-21-2018 09:19 AM
Okay, I feel like an idiot, but for anyone who runs into something similar. Check the battery cables, and then check them again.
I checked them when this first started and I would swear they were tight. I checked again this morning and the positive cable was loose.
Always check the cables.
https://www.facebook.com/JayShettyIW/videos/cindy-healy-always-check-the/1872493876161127/
Dave at Pelican Parts 07-21-2018 10:29 AM
Cool vid!
Yes, the slamming the door and changing the behavior is a big sign that something, usually an electrical connection, is loose. Glad you found the source of the problem!!
--DD
scubus 07-21-2018 01:56 PM
Originally Posted by Dave at Pelican Parts (Post 10115766)
Cool vid!
--DD
Thanks. BTW, my reply didn't post. It says it is waiting for moderator approval... is it the link?
Dave at Pelican Parts 07-21-2018 08:00 PM
Could be the link coming from a new user. I did see it, but I am in the admin group.
--DD
