Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
speedman's Avatar
Broken Crankshaft Damper
My 05 MCS has destroyed the rubber centered crankshaft damper. I have a new one from ATI ( Super Damper), but when i install it the new damper slides right on. This cannot be a good thin. I am thinking I will pin the damper to crank. Is there any other ways to make this repair without having to remove the crankshaft?
Rick T
Old 01-24-2020, 10:46 AM
j911brick's Avatar
What did you do?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 02-05-2020, 11:30 AM
speedman's Avatar
I will try a repair this weekend. I will drill the damper and crank to accept a removable dowel pin. A bunch of companies that sell supercharger conversions have you pin the crank, so I think it will work. I have not seen any issues the way it is right now, but a MC mechanic told me that if the damper slips it will cause the car to throw an error code. I have a reoccurring P1498 that comes and goes
Rick T
Old 02-05-2020, 01:18 PM
