300/present trouble code
I am getting the following codes after replacing the cross engine water pipe and replacing the vacuum unit.
The battery was disconnected for this work. http://forums.pelicanparts.com/uploa...1593023485.jpg 300/present - Exhaust camshaft sensor, electrical short to B+ 2C58/present - Charging pressure control: Switch-off as consequence. I have checked the wires from the cam shaft sensors - no shorts Switched sensors cleared codes problem returns. both cam shaft sensors were replace last month while fixing a VANOS issue. Any help would appreciated. |
| All times are GMT -8. The time now is 04:02 PM. |
