Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
2009 base Mini Cooper codes galore and bizarre behavior
My daughters '09 Mini (114,000 miles) has been giving her fits for months. It runs perfectly sometimes for days; then dies at a stop light or starts sputtering and surging with corresponding smoky exhaust. Or it can happen at high speeds too. I drove it 14 straight hours from Missouri to Texas without a single incident. The next day, it started shuddering and smoking while driving down the freeway at 70mph. It just comes and goes. I've never driven one before but was very impressed with its performance and handling until it goes into "crap" mode. It also uses more oil than I am used to seeing but I have seen some posts that suggest it is common for Minis.
The cam sensors have all been replaced. And I just replaced the downstream O2 sensor after codes pointed me in that direction. If anything, it got worse.
Current codes: P15E8, P0420, P0141, P0136, P2096, P115C
I would appreciate any insight or advice. Thank you.
Old 10-30-2021, 12:57 PM
Super Moderator
cstreit's Avatar
Dealer told me that the Mini can use up to a quart of oil every 700-1000 miles so that’s “normal.”
What are those codes?
Low oil will cause issues with the vanos that throw up a ton of fault codes.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-12-2021, 06:28 AM
