Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Where should this connector be?!
Hello all
Newbie here. I hope you can help with our Mini R53 2005 Cooper S.
Having discovered fuel gauge not working, I have found this connector floating about around the LH footwell/fuse box and wonder where it should be. As much as I am able to understand from wiring diagrams, this seems to be related but I’ve not been able to find the obvious place to reconnect it.
I wonder if one of you experts might be able to point me in the right direction.
Thank you for your help
Old 03-03-2022, 01:18 AM
Found the solution, having taken glovebox apart.
Found it to be the footwell lamp. (Now have illuminated passenger feet but still no fuel reading!)
I shall follow the methods of other posts as regards fuel level senders/pump etc.
Have a good day all
Old 03-03-2022, 06:14 AM
Tags
where does this go?!
