-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   R53 spark plug change (http://forums.pelicanparts.com/mini-discussion-forum/1120417-r53-spark-plug-change.html)
2004 Mini 06-07-2022 06:54 PM
Hi all,
Is using a torque wrench when replacing the spark plugs necessary, or will simple hand tightening with a socket wrench be enough?
Thanks in advance
rgc0233 06-17-2022 01:03 PM
Yes, plugs should tightened to specified torque. Gen 1 engines had a tendency to eject the plugs, taking the threads out with them. Torquing eliminates over-tightening, which may weaken and damage threads.
javadoɡ 03-28-2023 09:00 PM
You can get away with not using a torque wrench, the critical thing is to not over-tighten because you could strip the thread out of the head. Then you would need a repair of that, I think with a helicoil.
colingreene 03-29-2023 05:56 AM
always torque them 22-24 ft pounds.
