R55 N14s Another Crank, but No Start
Hi,
I have 2010 R55s with an N14 turbo (stop laughing in the back!). She’s aged, but only has 36k miles. Reason for the post, CRANKS, but NO START, not even a sputter. No previous symptoms, except some fault codes and low oil pressure at idle (which I was starting to tackle). Trouble codes:
Key to note these codes existed before the no-start and she’s gone 6k miles with them. I’ve been working through other issues. Not a starting issue until now (after sitting for a four-day weekend). What I think I know so far:
At the coils connectors I can see a good ground, about 11.4-V supply (cranking), and I see this from the ECU transistors: So, referenced to chassis gnd. (hence the noisy sig.?), 11.4-V on the power pin (cyan), the pull down & spark from the ECU (yellow). Fuel observations:
I thought the HPFP was mechanical, and am not clear on what its connector does. I do not have a fuel pressure measurement system that’ll fit anywhere on this car—which sucks. Pop-off the LPFP feed to the HPFP and let it squirt into a receptacle? Pull an injector and do the same? Remember, it’s not even sputtering—'hard to see it being one injector. I read about an “emergency mode,” wherein the system will still try to push pressure if there are problems like a fuel pressure sensor failure? Or are the earlier codes likely to be an issue (now, after 6k miles of driving)? I’d really like some help ladies & gents, -Jeffrey B. http://forums.pelicanparts.com/uploa...1695661761.jpg |
| All times are GMT -8. The time now is 12:06 AM. |
