Hi and thanks for the write up. I tried doing the project today and got stuck at the part where your remove the sprockets, mine were so tight one that I couldnt even move them a bit. My questions is on figure 16 do you push on the allen hex key up or down. I was pulling up and not sure if it is a left-hand threaded or something. thank you
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Window Regulator Replacement |
Remove it by rotating counter-clockwise. If it is too tight to remove, you may need the special tool to break it free.
- Nick |
| All times are GMT -8. The time now is 07:21 AM. |
