My above fan on my R53 appears to be on permanently on, so I suspect a faulty thermostat and would like to change it.
Do you sell just the P/S/pump thermostat or is it built into the connector shown in your figure 1 above please ? Thank you __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Power Steering Fan Replacement |
The PS steering cooling fan is activated by the same relay that activates the engine cooling fan. If both fans are stuck On there may be a problem with this relay.
- Nick |
