Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
silverfox56 (guest)
Guest
Posts: n/a
My above fan on my R53 appears to be on permanently on, so I suspect a faulty thermostat and would like to change it.
Do you sell just the P/S/pump thermostat or is it built into the connector shown in your figure 1 above please ?
Thank you
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Power Steering Fan Replacement
Old 04-24-2013, 05:21 PM
Nick at Pelican Parts's Avatar
The PS steering cooling fan is activated by the same relay that activates the engine cooling fan. If both fans are stuck On there may be a problem with this relay.
- Nick
