Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
oldvet53 (guest)
Guest
Posts: n/a
Can a scissors jack be used in place of the factory jack as when I got my '03 MCS it had no jack,lug wrench just the small bag with screwdriver and tool to remove the hub caps and a 13x10mm open end wrench and a socket. I picked up a 1 1/2 ton sicors jack and 2 wheel cocks and a plug in air compressor and a bottle of slime for emergency tire repair.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Jacking Up Your MINI
Old 04-24-2013, 05:27 PM
Nick at Pelican Parts's Avatar
If the jack is used properly and you jack in the correct place it should work fine.
- Nick
