Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
alan (guest)
Guest
Posts: n/a
For anyone who might have a heater problem where only cold is blowing out,i suggest you check the cable connection as mine had popped out of the control linkage that operates the vent.This is easily acessed by removing the right hand compartment tray.Found this out after checking thermostat,heater hoseswarm,and for any interior leaks from heater matrix.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Radiator, Thermostat and Hose Replacement
Old 05-07-2013, 05:53 AM
Nick at Pelican Parts's Avatar
Thanks for the great tip.
- Nick
