Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Doug (guest)
Guest
Posts: n/a
Along with the Bentley manual, this was a life saver. The photos were an excellent resource. Unfortunately, tightening the star washers with the window in the up position is impossible. I still don't have the window perfectly set.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Window Regulator Replacement
Old 05-08-2013, 04:24 AM
Nick at Pelican Parts's Avatar
It can be tough. The special tool is a life saver. You could always check if there is someone local willing to lend it to you. Or have a shop tighten them for you.
- Nick
