Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Ted (guest)
Guest
Posts: n/a
Great write up but have question about filter replacement. On Figure 24, it says to use hammer/flathead to remove. Does it screw in or do you pry it out?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement
Old 05-15-2013, 04:07 AM
Nick at Pelican Parts's Avatar
In firgure 23: http://www.pelicanparts.com/techarticles/MINI/17-FUEL-Fuel_Pump_and_Filter_Replacement/images_small/Pic23.JPG You can see the retaining ring still in place. It unscrews in a counterclockwise direction.
The ring is already removed in firgure 24.
Once the ring is off, the fuel pump module will pull stright up.
- Nick
