Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Peter (guest)
Guest
Posts: n/a
My Mini is slow to fire. Letting the fuel pump cycle a few times seems to allow it to light off first time. Is there a check valve on the fuel pump that can be replaced? Is there a check valve at the pressure regulator?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: MINI Cooper - Fuel Pump and Filter Replacement
Old 05-22-2013, 04:26 AM
Nick at Pelican Parts's Avatar
The check valve is built into the fuel pump. You can test is by checking fuel pressure, then allowing system to sit under pressure while you monitor it. It should hold pressure with the key off.
Drop our sales department a call at 1-888-280-7799 they can get you a repair manual with the test included.
- Nick
