-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Window Regulator Replacement (http://forums.pelicanparts.com/mini-discussion-forum/764563-question-window-regulator-replacement.html)
Steve (guest) 08-06-2013 04:52 AM
Thanks for the write-up. Job went well but the motor runs backwards. Up is down and down is up. The "dip" happens at the bottom. How can I fix? Dealer said they'd never heard of the problem, but I've seen it on forums before but never an answer other than "reprogram" the module. Is there another option other than a $125 shop charge at MINI? Many thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-06-2013 04:52 AM
I have not run into this problem. There could be a wiring issue witht hemotor, the polarity could be switched. I would check with MINI to see if programming wil remedy the issue.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
thad1947 01-15-2014 07:13 PM
I had the same trouble and found this youtube. Up is down problem is corrected.
REMEDY MINI COOPER WINDOW WORKING BACKWARDS - YouTube
