Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Steve (guest)
Guest
Posts: n/a
Thanks for the write-up. Job went well but the motor runs backwards. Up is down and down is up. The "dip" happens at the bottom. How can I fix? Dealer said they'd never heard of the problem, but I've seen it on forums before but never an answer other than "reprogram" the module. Is there another option other than a $125 shop charge at MINI? Many thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-06-2013, 04:52 AM
Nick at Pelican Parts's Avatar
I have not run into this problem. There could be a wiring issue witht hemotor, the polarity could be switched. I would check with MINI to see if programming wil remedy the issue.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
I had the same trouble and found this youtube. Up is down problem is corrected.
REMEDY MINI COOPER WINDOW WORKING BACKWARDS - YouTube
Old 01-15-2014, 07:13 PM
