-   MINI Discussion Forum (http://forums.pelicanparts.com/mini-discussion-forum/)
-   -   Question on Oil Change (http://forums.pelicanparts.com/mini-discussion-forum/766749-question-oil-change.html)
Edison (guest) 08-19-2013 05:49 AM
Quick question I've been reading about r53 oil filter housings
Apparently older r53 might of had the plastic Cage and spring setup....
However I don't remember my 2003 r53 having that.
Do you have any insight on this ? It seems to apply to regular mini coopers, but I keep reading so many conflicting info for the mcs
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 08-19-2013 05:49 AM
Models before 7/2004 had the metal housing with the plastic cage. Models after 7/2004 has the metal housing without the plastic cage. An updated filter was introduced with the later models, replacing the early filters without an internal plastic support.
- Nick
