Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Edison (guest)
Guest
Posts: n/a
Quick question I've been reading about r53 oil filter housings
Apparently older r53 might of had the plastic Cage and spring setup....
However I don't remember my 2003 r53 having that.
Do you have any insight on this ? It seems to apply to regular mini coopers, but I keep reading so many conflicting info for the mcs
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-19-2013, 04:49 AM
Nick at Pelican Parts's Avatar
Models before 7/2004 had the metal housing with the plastic cage. Models after 7/2004 has the metal housing without the plastic cage. An updated filter was introduced with the later models, replacing the early filters without an internal plastic support.
- Nick
