Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Mini Cooper Hill (guest)
Guest
Posts: n/a
05 Mini Cooper S Car was sitting for a year and a half. Car would not move after new battery was installed. Would changing the transmission fluid solve this problem? Low energy light comes on inside the car.
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-09-2013, 05:01 AM
Nick at Pelican Parts's Avatar
The vehicle starts and run, but does not drive? Did it drive before it was left to sit?
I would start by checking the transmsiison fluid level.
- Nick
Wyvern's Avatar
I worked on one that sat foe just over a year . ..
It took moving to drive , N , P , R a few times then she started gripping.
The transmissions are "sealed" but fluid can be changed (it is an interesting system that you need to do (I have a container and hang it from the rafters and use gravity / trans pump to do the work .)
Brian
Old 09-10-2013, 09:15 PM
