Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
max (guest)
Guest
Posts: n/a
Replaced the fuel pump and filter. Now thw car isn't getting any fuel pressure? any ideas?
This post was auto-generated based upon a question asked on our tech article page here:
Old 10-15-2013, 04:19 AM
Nick at Pelican Parts's Avatar
The fuel pump is likely not connected properly. There could be an issue with the wiring where the pump is not turning on, or a problem with a hose connection, allowing fuel pressure to bleed off.
- Nick
Fuel Pump
Taken out the fuel filter and nothing seems to be blocked in the hoses or the fuel filter itself would it be worth buying a new sender unit?
Old 10-15-2013, 03:42 PM
Hell Belcho
Nostril Cheese's Avatar
Did you prime the fuel lines?
Old 10-16-2013, 10:31 PM
Sorry i have been away on holiday.
No i haven't primed the fuel lines ill try that in the morning and see if anything happens
Old 10-25-2013, 03:53 PM
