Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Kelvin (guest)
Guest
Posts: n/a
Respected Nick,
Very informative and thank you for writing something so detailed like this. My question is that do you need to change fuel pump Feeding unit as shown in pictures along with Filter when you do it? Or can you just change a fuel filter and use the pre-installed fuel pump. Would it effect the car or performance or fuel pumping behaviour in anyway? Also do i need to replace levelling sensors while carrying out this procedure? Can you kindly confirm? Thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-13-2013, 07:10 AM
Nick at Pelican Parts's Avatar
You can exchange just he filer. I would replace the sealing o-rings as well. The sending unit should not have to be replaced if it is is good condition.
- Nick
