Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mike (guest)
Guest
Posts: n/a
I've had zero success retracting my rear right piston on a Mini Cooper S. Just pressing on the piston does not seem to be sufficient. I've seen other forums discuss the requirement to rotate the piston as well as compress it. If that is indeed a necessary step, it would be a good thing to add to the instructions.
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-21-2013, 03:55 AM
Nick at Pelican Parts's Avatar
You do have to rotate the piston with a special tool. I will have this step added to the tech article. Thanks for the feedback.
- Nick
