Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mellow yellow mini me (guest)
Guest
Posts: n/a
09 R56. Light acceleration between 2 and 3k rpms I get slight miss/shutter from engine also when it sits for 8 hours or so, I get an extended crank. Noticed if I'm sitting at a stop light and tap the throttle quickly, the idle drops down and runs rough, then slowly comes back up. Does this sound like a fuel pump or ignition issue. Sound like fuel to me. Any help would be greatly appreciated.
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-04-2014, 11:51 AM
Nick at Pelican Parts's Avatar
I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick
